Old 11-14-2005, 11:27 AM   #1
Green Stallion
CJ5.0's Avatar
Send a message via AIM to CJ5.0
sub and amp
i know this is somewhat of a repost but im still a little confused. I have the stock radio with the cd player on my sn95 so can i or can't i put a sub to it
the sub will have its own amp, nothing will be wired to any of teh other speakers so will it ruin it or not.
Originally Posted by PonyTx
someone has shit on the coats.
www.stangology.com
CJ5.0 is offline   Reply With Quote
Old 11-14-2005, 04:32 PM   #2
01SilverSVT's Avatar
Send a message via AIM to 01SilverSVT
Yes you can... I have a seperate amp and sub hooked up to my mach 460 system
01SilverSVT is offline   Reply With Quote
Old 11-14-2005, 06:12 PM   #3
Send a message via AIM to SAvoltage Send a message via MSN to SAvoltage Send a message via Yahoo to SAvoltage
can be done with the mach system, tricky though plenty of walk throughs all over teh interweb.
SAvoltage is offline   Reply With Quote
Old 11-14-2005, 07:31 PM   #4
Green Stallion
CJ5.0's Avatar
did you install yourself?
www.stangology.com
Old 11-14-2005, 07:45 PM   #5
superGT's Avatar
so can you put a aftermarket cd player and keep the 460 speakers
JUST LOOKS STOCK!!!
superGT is offline   Reply With Quote
Old 11-15-2005, 12:08 AM   #6
I am my post count!
I'm not sure about the Stock Mustang radio, but you will need a pre-out for the amp. They are very common on today's radios, but there are some car's that still don't have them.
The sub will work, but I'm not sure how "much" it will be able to "drive" the sub.
Mestizo is offline   Reply With Quote
Old 11-15-2005, 12:16 AM   #7
I am my post count!
Yup.
Usually you want to start a sound system from front to back. Headunit(), front speakes, rear speakers, and sub system.
Old 11-15-2005, 02:06 PM   #8
No I didn't, it was done WAY before I got into understanding stereo systems... was the first mod to my car, lol... Anyway, it's a pretty simple set up... just have to tap the stock amps there are a ton of walktroughs on the net... Anyone that does car stereo installation should be able to help you out too.
Old 11-15-2005, 02:08 PM   #9
The sub will work, but I'm not sure how "much" it will be able to "drive" the sub.[/quote]
It drives VERY well... although if I had an aftermarket deck it would be more of a difference, but I'm happy with how it sounds now... (and I believe the power issue is because the stock system runs at like .5 volts ... where as most aftermarket ones are what 2-4 ??? Someone correct me if I'm wrong on this one)
Old 12-09-2005, 03:49 PM   #10
Not hot..
Chili's Avatar
I have an aftermarket amp and sub on my 460 but Circuit City installed the amp.. I have no issues with driving the sub.. In fact, I only have 200 watts (@ 2 ohms) running the sub (JL 10w3v2) which can handle a good deal more. Any more and I get too much vibration. I don't really want to use dynomat, etc. due to the weight..
Sub comes out at the track
2004 Torch Red GT
Best 1/8 8.61 @ 81.59
