#2 | |
Full of information
check out my other thread
Pics of my custom rear seat delete and damn tire
<><'98 BAB Cobra #3392 of 5174 Modded-446RWHP/408 RWTQ<>< Quote:
☆★sSs★☆
when you say "in the back seat" what do you mean by that?
i got the same set-up and its all in display. i mounted the amp to back of the seat. a custom fitted box that hold the 12's that fits just w/ in the opening of the trunk rectangle hole. caps can go on either side of the trunk either strap't or burried |
are you replacing the back seat with the set up?
Like a custom box in place of where the back seat used to be? I could invision a custom box with 1 12" on each side with the amp in front on the floor area and the other parts on the sides and between the speakers. all fiberglass finished or upholstered, but with that smooth shape that matches the interior filling where the seat used to be. like you would see in a show car |
http://www.cartunes.com/installs/for...R/rear_sub.jpg
here is a pic of one in a mustang I would rather see the sub on the back facing forward (also angled and sticking out some,not just flat) and the amp and stuff on the bottom Maybe incorporate the center console into the shape, like have the amp over the hump mounted in/on a shape like the console extended to the back. OK enough ideas, lets get some feed back Last edited by keg65; 01-31-2007 at 08:38 PM. |
#8 | |
Full of information
like mine?? if so i have a guy that builds them for about 150 bucks
rookie
ok, i pretty much decided to run with something like what keg65 posted. the box is basically the same but i can't get mine to lay as flat as that. but there will be a beauty board to cover up everything that doesn't sit flush. oh and my amp will be mounted in between the subs,angled foward.i'm not installing the caps unless the system really drains alot of power. i'm toying with the idea of plexy glass and all,but i don't wanna cross over the rice line.
