#22 |
BUT he has sportlines according to his sig... that's a HUGE difference... lowering 1.5 inches versus close to 3.... my customer will be fine w/o an alignment for a while.
edit... and just to verify, it's ultimately his choice... i'm merely running the shop where the work is being done at, and he asked me to help him research.. but since everyone is too busy talking about eachother's shit rather than helping me answer the question at hand... it doesn't even matter anymore...
t-5 swap, billit quadrant, upr firewall adjuster, steeda tri-ax, custom jb tool and fab one off subframe connectors. coming soon: 8.8 w/ 3.55:1's, '00 gt brakes, followed by my 306 swap |
#23 |
God's gift to Dell
i think you are taking things a little our of proportion. All you have told is that he has a fox body, not what he wnats to get out of the car, either drag or street...more information could get you alot better answers i bet
#24 | |
Evil Angel
#25 |
God's gift to Dell
people reccomend things because they have had experiences, or know people who have had experiences that stemmed from not taking said avice. Dont buy caster camber plates, but if you dont, expect your alignment to be off. Dont lower your car without replacing the factory shocks and struts with new ones, unless you plan on the ride being shitty..shall I continue?
#26 | |
Evil Angel
#27 | ||
re re
#28 |
jody, i'm no where near over my head on this, i realise i'm no professional, but i've grown leaps and bounds in that direction since i've last talked to you... i realise it would be the RIGHT THING to have him buy c/c's and everything and i did tell him that from the get go, the car is an 03 gt and the main purpose of this thread is to determine if there is a strut that he can run that's not as pricey as tokicos or something like that where he wont have issues with them blowing out really soon... however, i am gonna take some advice.. i'm gonna shop around for him for the best prices on what he NEEDS and tell him to come see me when he's got the money. i'm already saving him tons of money on the install over everyone else, so he should be ok on this.
#29 |
God's gift to Dell
i told you already that for the money, KYB's are not bad. They come in a package of shocks and struts for $250 bux, how much cheaper can you get? He is ignorant to do the install with cheap parts, and then when they break, he has to do NEW parts, AND pay the labor all over again. Why not do it right the first time?
#30 | |
re re
Just buy the house brand of the parts store or even get Monroe, still better then stock, if you think that they will "blow out soon" cuz it is lowered, you obviously are not learning enough yet.
#31 |
Evil Angel
I already said that... GOSH! HAHA...
#32 | |
#33 | |
your stock stuff is better and will hold up longer than some cheap monroes. when you lower the car, it is compressed too low and the piston doesnt have as far to travel. It is more cpomplex than that, but many lowering springs will blow out your stock struts
#34 | |
Maybe you guys drive on flat surfaces liek a grandma all day, I dont know....
#35 |
we'll were all assuming the drop is for a daily driver which would be for mostly cosmetic purposes and assuming he drives normally and not too aggressive but the information wasn't disclosed.
#36 |
God's gift to Dell
exactly....how are you going to bash our suggesstions when you give us hardly any information?
#37 | |
Evil Angel
#38 |
who the hell said he would need fox style struts? can you not read?
I said specifically what I meant. If you go with any good spring, you should use any aftermarket struts. Not some autozone piece of poo. if you go with an HR SS or stiffer, or a sportline, you are going to be out of the efficientcy of the stock strut. It will last.... for a while. It will also ride rougher than if you had aftermarket struts that can handle our heavy blingtastic deep dish 27 pound ford wheels and our drop. I dont autocross or road race, but the H&Rs were enough to blow a brand new stock replacement strut. I have seen it on several cars, Hell, there is even an article on the web of a spring install on a Mach 1 with its better than stock GT struts. Guess what, it blew them! what did I bash? The fact that Jodi said a lowered car would not neccessitate a good strut? Sorry, but i actually get passionate about things when someone gives misinformation over the internet that will cost people undue troubles. Not every body can afford to do things right the second time.
#40 | |
Evil Angel
He asked about using fox struts in the very first post. And second...that's exactly our point. Do it right the first time, so you don't have to do it a second time. No one here has said to do it twice, everyone said do it right the first time.
