Old 08-13-2007, 06:24 AM   #1
Send a message via Yahoo to Southernstang93
suspension info
I have a 67 and was told that it was a v6 car that was changed to a v8 289 , how do i know if the suspension is still v6 stuff and how do i go about changing it ,, it seems to hold the v8 just fine... safe to say got a lot to learn about this one...
Southernstang93
many upgrades
Southernstang93 is offline   Reply With Quote
Old 08-14-2007, 05:39 PM   #2
Check ya later!
Is it still 4 lug?
Old 08-14-2007, 09:46 PM   #3
Box Foxes Rule!!!
racer99's Avatar
A straight 6 car.
of stupidity!
78 Zephyr, 306 turbo
82 Granada Wagon,306 150 shot
88 Mustang 2.3 turbo 100 shot
Old 08-23-2007, 02:30 PM   #4
its still 4 lug and has a 289 , with a c4
Southernstang93
many upgrades
Old 08-23-2007, 02:32 PM   #5
It was a 6cyl if it is 4 lug.
You really need to upgrade to 5 lug spindles and the bigger rear axle plus youll get improved brakes in the deal
Old 08-23-2007, 02:40 PM   #6
i plan on putting disc in the front and would like to put a 8.8 with drums in the back...but you know how it is , time and money ...... more money than anything :0)
Southernstang93
many upgrades
Old 08-23-2007, 02:56 PM   #7
Youll have to change the spindles to get disc brakes on the frt and you really should get V8 springs in it as well
Old 08-24-2007, 03:27 AM   #8
Hmbre97's Avatar
You can keep the drum spindles and buy adapters to use the SN95 Cobra/Mach 1/Bullitt 13" front setup. You have to run 17" wheels with it though.
-Herb-
03 TR Mach 1
Hmbre97 is offline   Reply With Quote
Old 08-24-2007, 09:04 AM   #9
keg65's Avatar
Don't those adapters only work on V8 spindles?
or are they the same for a 6 cyl in 67?
