Suspension Work
Well guys, need some advice. Thinking about getting sub frames and upper and lower control arms on my 04 GT. Some one told me if I wasn't going to get real aggressive at the track to just get the sub frames and upper control arm. What's the difference in putting both control arms or just one? Would it be worth it to do suspension work or do stuff the the engine. It's a stock engine as of right now. Thanks in advance.
#2 | |
AKA silver1988stang
![]() XplicitPerformance.com |
#3 | |
you just don't know!
yeah i have my suspension all beefed out (control arms, sway bars, subframe, strt tower brace, springs, struts, etc) with basically just bolt-ons on the motor.. i love it! it even stays where you point it in the rain!! :redrum: :redrum:
you might want to invest in a good rim/tire combo, too. i ran the modded suspension with both the stock 8" wide bullitts and some 10.5" wide cobra r's on the rear and 9" wide on front.. the cobra r's with good tires make SUCH a difference but like diesel said, Quote:
![]() If you support the policies and character of John McCain, please drive with your headlights on during the day. If you support Barack Obama, please drive with your headlights off at night. |
uhh if im correct, the lower bears most of the load so that would be first.. but if you can afford it, id say go for both
Thanks for the info. Right now nothing is done to the engine just a K&N filter. I also have 3.73 gears, UPR o/r x-pipe w/spin techs and a steeda tri-ax shifter. Went and got me some Mickey Thompson ET Streets. Work pretty good. Ran a 13.7@99.32. Need a little more practice w/ them. First time using drag radials. I don't think it's too bad though.
#7 | |
AKA silver1988stang
#8 | |
Damn, didn't know that. I'm hoping to get the suspension work done in February for my b-day. Trying to convince the wife to hook me up so I can hook up better. ![]() |
Parts guru
Like every one said before build the suspension to fit your "final" :jmg680: engine combo, that way you don't have to do things over and over again....as for subframe connectors, not all are the same...ie quality, fitament etc. I would suggest full length connectors from Maximum Motorsports, for some of us it's overkill but, with these you know nothing is goin' to move on ya. It's also a good foundation if you ever decide to seriously race the car...my .02
Opinions are like a$$holes...everyone has one, especially on the internet.... |
#10 | |
Thanks for the advice. |
