Old 09-30-2004, 10:19 PM   #1
throttle body for an '86
can any of you guys ansewer a question for me? i"ve got an 86 that still has the speed density setup on it. this car has e-7 heads on it right now. my question is i have a gt 40 intake that i want put on this car and some one that i can buy a 70mm throttle body off of for real cheap. will this setup work and run alright until i switch it over to mass air setup. i also have aset of 24 injectors to go along with it. :fruit2:
boz351 is offline   Reply With Quote
Old 09-30-2004, 10:20 PM   #2
i almost forgot the throttle body is from a 91 lx. :fruit2:
Old 10-01-2004, 06:59 PM   #3
Yes it will work. The 24# injectors might be a little much if you dont have a set of decent heads. There really is no need to switch over to MA until you change the cam, even then there are a few cams that work well with SD.
I still run SD and have talked to a lot of people that have good results with it.
Old 10-01-2004, 07:43 PM   #4
i forgot to say that i do have b303 to go along with it. i've just heard nothing but bad stuff about sd. i had nothing but maf on all my other mustangs,this is the first car i've had with sd. so any tips or tricks would be appreciated.
Old 10-01-2004, 07:44 PM   #5
You are still slow! :jester:
Old 10-01-2004, 07:45 PM   #6
not true
Old 10-01-2004, 07:46 PM   #7
If you want an good everyday strret cat that you can mod the hell out of then go mass air.You can get away with quite a few tricks as Hoss has stated with SD but for anything radical you will need a chip to get the most benefit from it.
Old 10-01-2004, 07:51 PM   #8
that is pretty much what i am looking to do for right now until get done with the 331 that is half built for about the last year.
Old 10-01-2004, 07:57 PM   #9
What's the compression ratio on the 331?You have any heads picked out?
Old 10-01-2004, 11:19 PM   #10
Any of the alphabet cams will not work with SD. Crower and Comp both make good cams for SD.
