Old 06-23-2008, 05:55 PM   #1
mach1r's Avatar
torque to spec
how do i know how much torque each bolt needs?
to spec where can i find out?
im rebuildin my engine
mach1r is offline   Reply With Quote
Old 06-23-2008, 05:57 PM   #2
Trader Rating: (20)
On a mod motor I assume??
If so.......
Stage 1: tighten to 40 Nm (30 ft. lbs.).
Stage 2: tighten an additional 90°.
Stage 3: loosen the bolts a minimum of one full turn.
Stage 4: tighten to 40 Nm (30 ft. lbs.).
Stage 5: tighten an additional 90°.
Stage 6: tighten an additional 90°.
From the inside out on stock head bolts.
Old 06-23-2008, 06:09 PM   #3
mach1r's Avatar
yes
Old 06-23-2008, 06:12 PM   #4
Trader Rating: (20)
see above
