Old 09-17-2007, 07:12 PM   #1
NoObie
Kingpin's Stang's Avatar
Exclamation TPS problem...need help please!
My TPS (throttle body sensor) is running at 13% and will not zero out. I've replaced it 3 times with the same end result. Does anyone have any ideas or suggestions?
Kingpin's Stang is offline   Reply With Quote
Old 09-17-2007, 08:00 PM   #2
mis adjusted idle screw???? that's a lot though... check your throttle cable for any kinks or something i guess..... start with that.. maybe check your throttle pedal
Old 10-12-2007, 08:55 PM   #3
Supercharged
Send a message via AIM to VCS_SSSTANG
Weird, I had one do that... However I replaced it and no problems. Make sure you clean everything.
232CID, 6CYL, YEP!
VCS_SSSTANG is offline   Reply With Quote
