Traction Lock Rebuild
I'm starting to get a one tire fire every now and then. So I think it is time to re-build my stock t-lock. What are my options and I have heard it is really easy? Give me some input. Thanks
![]() 1988 Mustang LX |
MODIFIED
just need to get a rebuild kit for the ford tlock. if its a stock part
![]() Ive never done one dont know how complicated it is.. im sure the hard part is aligning the gears
00 White Wingless 5speed- Modified MAC CAI, Spintech Dual Side exit exhaust, Prokit, 99 GT Rear Swaybar, AGX 5 way Adj., FRPP Clutch, MM Firewall Adjuster, MM Clutch Quadrant, ASP U/D Pullies,MGW Short Shifter, MGW Billet A/C knobs, MGW Locking Fuel Door, Upgraded Seats, Custom Interior Paint, Interior LED Setup, MM C/C Plates, MM STB, Cobra Brakes, Sequential Turn Signals, Saleen Front Facia, Stalker Hood, Sonic Blue DD Bullitts. |
...So I dub thee Unforgiven.
i heard it was real easy. i was going to get it done, but when i went to go get the rebuild kit, THRS just happened to have a rebuilt tloc sitting in the shop for 40$ so i just took that one. haha
Either I can rebuild the one that is in there now or find another posi for cheap and rebuild it and swap them out. Does anyone have any idea how much a bad posi will hurt me at the track?
MODIFIED
Yeah, thats about the price I have seen everywhere. I also want to get the F-150 S-spring and there are different ways of alternating the clutches and steels to optimize the amount of tourque that can be applied to the rear wheels.
Hey, smell my finger
It is real easy to do. I have done a couple. Dont forget the additive when you fill the case. And if you are using slicks at the track and you hook with a bad t-lok you can lose control and eat the wall!
It comes with instructions on how to stack them and yes I packed it a little thicker. Use a mic if you can to see how thick you can go, it will tell you how thick it should be and I think I went with one extra clutch. But when you go a little thicker it gets to be a bitch to put back together.(a little tight)
This is what I was going to go by.
http://www.angelfire.com/theforce/5o...5ohtech018.htm And use a F-150 S-Spring. What do ya think?
