Old 02-19-2008, 10:45 PM   #1
2002 Mustang GT 5 Speed
MustangGTRound2's Avatar
Tranny?
Hey, i have a 2002 4.6 with a 5speed tranny. Bought it used not too long ago at 55k miles and it is starting to Chatter at high RPM(4k or heigher). When cold the chatter is twice as loud.... I try not to push it due to the fear of breaking something. Anyone have any ideas? (for those that may have this qustion, there is NO sliping when changing gears)
MustangGTRound2 is offline   Reply With Quote
Old 02-19-2008, 11:06 PM   #2
thesource's Avatar
Trader Rating: (13)
Sounds like an issue with the pressure plate . I would probably have it looked at pretty quick before something more serious happens and either ruins the bellhousing of the trans or worse .
Old 02-20-2008, 07:10 PM   #3
Took it to a tranny shop and they said the same thing... they want to lift it no charge to make sure tho. If im going to mess with the clutch im going to replace with a performance clutch. Any recommendations? nothing very expensive.... this is my daily driver and i just want a nice stiff clutch that feels good performs well and will be at a good price.
2002 Mustang GT 5 speed Dark Red..... a.k.a. my second chance....
Old 02-21-2008, 08:35 AM   #4
thesource's Avatar
Trader Rating: (13)
Either a SPEC stg 1 or something like the LUK clutch will work great for you .
Old 02-21-2008, 11:12 AM   #5
always asleepn
tulabeast's Avatar
get a king cobra maybe like 200 bucks brand new might be even cheaper. for a daily driver
98 gt on the streets.
mod motors suk
Old 02-21-2008, 11:22 AM   #6
LOL @ your mom
Trader Rating: (22)
Whatever you buy, buy it as a kit. Clutch disk, pressure plate, throw out bearing and pilot bearing, and get the flywheel resurfaced.
Old 02-24-2008, 12:53 AM   #7
It's LOUD but YOU looked!
stangfreak's Avatar
has a point
ebay has alot of kits.
Deep thought...
Why do they call it an asteroid when it's outside the hemisphere, but call it a hemorrhoid when it's in your butt?
