I was like Tranny.........Just head downtown and ask around.....
But I see it isnt that kind a tranny....lol Hit up "thesouce" on here that is what he does Trannies........the kind for cars.
I actually have one with 500 miles on it . Its basically brand new . I pulled it out of a customers car last week .
T5z with Lakewood bellhousing & centerforce clutch |
You will need to change the bellhousing as well since Tremec / Ford never offered a T5Z for the 94-95 cars . I'd take $900 for it + your transmission . I'd swap you a Fox body bellhousing straight across for yours and you'd have to buy a fox body clutch fork for the fox body bellhousing .
I'm not bullshitting you about this unit being like brand new . If you are serious , PM me and we can go from there . |
yes they never offered a 2.95 ratio trans for the SN95 cars regardless of being a Cobra or not . All you have to do is swap the bellhousing and clutch fork and the fox body lenght T5Z will go right in . I just sold one the other day to a customer on this board and Lethal did the installation for him . He had a 95 Cobra .
#10 | |
you smell that?!
94 Steeda- sold- 355rwhp on a 75 ![]() 02 Roush 360R- sold- 400rwhp at 8psi ![]() 04 Mach 1- K&N drop-in, Roy's 3/8 spacer, Steeda tri-ax, Pypes o/r X, Super 44s, 04 Cobra IRS, 4.10s
Good deal , I'm glad he likes it . Denton's a little bit of a drive from S.A.
What is the difference in the T5z as compared to a borg warner t-5 or the stock fox body T5. OR am I confused. I just destroyed my transmission this past saturday. I want something with some nuts. I have a 347 stroker thats all motor right now and the freshly rebuilt T5 lasted 5 street passed on the slicks. What a disappointment. Hey source do you have anything that will hold up to 500hp/500tq? Thanks
The T5Z is basically a 1993 Cobra transmission with GM V8 Camaro WC internals and uses a special input shaft to make fit a Ford clutch . Its stronger than your basic Mustang T5 and has a totally different gear ratio better suited for higher powered cars . I've seen them hold up to as much as 500 hp but I've also seen them break with less than 350 . As for building a T5 to hold 500-550 hp , I would suggest the Astro Performance A5 gear kit . The problem is , they are on national back order and will be for some time .
