Old 03-28-2004, 07:53 PM   #1
Send a message via AIM to laser_RED_99gt
Transmission
Ok does anybody know if a 6-speed cobra transmission will bolt on to a gt engine? I would think so because it is generally the same engine, same size anyways except for the DOHC, but Im not sure. I also need to know what else I would have to buy if anything, and where I could get one at I couldn't find one on ebay? Thanks
laser_RED_99gt is offline   Reply With Quote
Old 03-28-2004, 08:01 PM   #2
Man law?
Try D&D motorsports, they should have everything you need.
Old 03-28-2004, 08:04 PM   #3
Mama Mia
68GEETEE's Avatar
Could try for a used one from a salvage yard. Call Acme Auto Parts on Somerset Road in San Antonio, if they dont have one they can usually locate it and have it brought in. Talk to Frank or Steve.
Old 03-28-2004, 10:05 PM   #4
Are they located in San Antonio?? Do they have a website?
Old 03-28-2004, 10:08 PM   #5
Man law?
They arent local. Not sure if its D&D motorsports or performance. I know its D&D something. Sorry i can't be of more help.
Old 03-28-2004, 10:13 PM   #6
it will bolt up just fine.
i think you need to modify the crossmember and use a different driveshaft. I think it needs to be shorter. need a new shifter of course.
I think the clutch will work, but i'm not sure. If you have to use the cobra clutch you will also need an 11" flywheel.
My Garage
Old 03-28-2004, 11:57 PM   #7
karma
Send a message via AIM to enouf4u
yust need to modefy crossmeber and order a speedcal extendet range the regular one wont work
AKA-Blewbullitt
enouf4u is offline   Reply With Quote
Old 03-29-2004, 12:03 AM   #8
you can use the same driveshaft?
My Garage
Old 03-29-2004, 12:05 AM   #9
karma
no u have to use the one out of the cobra u a lso need to change the yoke on the rear end since the cobra uses a biger flange
AKA-Blewbullitt
