Nope ..... its making noise because either its been ran low on fluid or you have excessive wear on the gears . You can go with a thicker fluid but its going to be tougher to shift when it get cold out side .
If it's whining it has problems. Such as bad gears, bearings or or just way too loose. If you are talking about a chattering when letting the clutch out, that is a flywheel,clutch and pressure plate problem. I the trans is making noises when letting the clutch out or getting on the throttle, your tranmission is loose, basicaly the shafts have too much end play, needs to be rebuilt. I would not drive the car hard if it has excessive end play it will not last long at any power level. Getting a T5 rebuilt is not a big deal, just make sure the person doing the work knows what they are doing, if it is not shimmed correctly you will have the same problems with the new parts.
The goal is to get the car to run 10.0 on radials,with out a power adder and still be streetable. My car is an '85 sonic blue coupe with 302 bored and stroked to 364, Ported Twisted Wedge heads and a BXR intake, A9M ECM with a Tweecer, C4 with trans brake, Hoosier 275/60/15 drag radials, no power adders. |
bingo!! my old t-5 i yanked out after 5th went out main shaft was loooosseeeee in it.....i run royal purple synchromax lube goood stuff for t-5's
1989 LX Coupe 5.0 HP/457 TQ/448 Um......STOCK? LOL |
You will never get this
I have a T45 and I need to know how to take out the drain plug on my tranny. Is there a certain tool? Im putting in a MGW shifter and Ive decided to just go ahead and replace the fluid too.
Use a 3/8 rachet to pull the drain plug and the fill plug .
Only had it a day and I am in love. |
