Old 12-15-2007, 04:21 PM   #1
greenjams's Avatar
Transmission Fluid
What is the best transmission fluid for a real winy T-5 transmission with 150,000 miles and is there any stuff you can add that can help with the chatter.
greenjams is offline   Reply With Quote
Old 12-15-2007, 04:39 PM   #2
thesource's Avatar
Trader Rating: (13)
Nope ..... its making noise because either its been ran low on fluid or you have excessive wear on the gears . You can go with a thicker fluid but its going to be tougher to shift when it get cold out side .
Old 12-16-2007, 11:48 AM   #3
Sonic Blue 85's Avatar
If it's whining it has problems. Such as bad gears, bearings or or just way too loose. If you are talking about a chattering when letting the clutch out, that is a flywheel,clutch and pressure plate problem. I the trans is making noises when letting the clutch out or getting on the throttle, your tranmission is loose, basicaly the shafts have too much end play, needs to be rebuilt. I would not drive the car hard if it has excessive end play it will not last long at any power level. Getting a T5 rebuilt is not a big deal, just make sure the person doing the work knows what they are doing, if it is not shimmed correctly you will have the same problems with the new parts.
Old 12-18-2007, 01:50 AM   #4
Lifted78Chevy's Avatar
bingo!! my old t-5 i yanked out after 5th went out main shaft was loooosseeeee in it.....i run royal purple synchromax lube goood stuff for t-5's
1989 LX Coupe 5.0
Tuned at PSI.pulled threw 5800 no stop shut it down at 6 grand....
Next motor all out with it...hope make 6-7 hundred hp
Old 12-27-2007, 01:05 PM   #5
You will never get this
Magnapack97's Avatar
I have a T45 and I need to know how to take out the drain plug on my tranny. Is there a certain tool? Im putting in a MGW shifter and Ive decided to just go ahead and replace the fluid too.
Old 12-27-2007, 09:18 PM   #6
thesource's Avatar
Trader Rating: (13)
Use a 3/8 rachet to pull the drain plug and the fill plug .
Old 12-27-2007, 10:55 PM   #7
Professional Leash Holder
TheBocSez's Avatar
Just put a MGW on my 00. Very nice piece.
Old 12-28-2007, 04:32 PM   #8
Only had it a day and I am in love.
