Old 05-19-2004, 04:41 PM   #1
Transmission Question?????
I have a 93 ford Explorer 4.0 v-6 2 wheel drive Auto... When it goes into Over Drive it will go but it wont go fast top speed around 60 or so at a high RPM ?? What is the deal???? Will a Trans out of a 3.8 V-6 work if not what is inerchangeable??????
extremestang is offline   Reply With Quote
Old 05-19-2004, 05:18 PM   #2
The token Asian guy
propellerhead's Avatar
Something is wrong there. I had a 94 Ford Explorer that would easily go 90+ MPH in overdrive. See a mechanic.
2004 Mustang GT
Old 05-19-2004, 05:44 PM   #3
Yup something is going bad sounds like a classic case of slipping which means shortly your OD will be going bye bye if you keep driving it take it to a trans shop and have it diagnoised.
Old 05-19-2004, 05:45 PM   #4
double post sorry
Old 05-19-2004, 07:17 PM   #5
Hey, smell my finger
firegoose's Avatar
It sounds like its slipping to me, word of advice, take to get fixed BEFORE it goes out completely or it will cost you more. And the more you drive it the more its gonna cost to fix it.
firegoose is offline   Reply With Quote
