fully ported block and bored out heads!
Tune??
just about finished my putting back together my car after like 2 years. Anyway i was wondering do i need to get a dyno tune when i get it running.
Forged engine with ported heads, mph turbo cams i dont know the specs though, stock intake, stock manifolds, 19lb injectors, stock MAF
2004 Mustang GT 9:1 Forged shortblock .20over w/team breed valve covers, ported heads, turbo cams, spec stage 3 clutch, spec flywheel, stock intake, stock manifolds, cai w/kn filter, c&l plenum, mac gutted catted h-pipe, battery relocation, 3.90's, qa1 k-member, subframe connectors, upr a-arms/coilovers, bumpsteer kit, steeda X2 balljoints, tokico adjustable drag struts/shocks, upr cc plates, tubular upper and lower rear control arms, welded axle tubes, 18" DD Black Cobra R's wrapped in nittos www.cardomain.com/id/66mustang04 T-70 Single Turbo build in progress...I cant wait!!!
#2 | |
o the cams do have 115lsa on them
so i cant use the diablo tune from my handheld?
it will be a bit lean and the car may not idle well with the out of the can tune.
Dumb and dumber
Custom tune will be your best bet and Dean at PSI does the Diablo tunes here. And with you being on LSS, he may help you out on price.
Check ya later!
I couldn't agree more........
