Old 09-13-2006, 09:33 AM   #1
superGT2000's Avatar
turbo, supercharger, engine swap
so heres the deal, in about 10 months my car would be paid off.....so this means i'll have more money to put towards it...i always love the 03-04 cobras..and well i don't want to gain a another car payments so would it be best to swap out the enigne with a cobra with all all the works, or should i just drop in a supercharger or maybe a turbo or two...i do plan on getting a beater to let the stang rest....any info will work...thanks
Old 09-13-2006, 09:48 AM   #2
FnSweet06's Avatar
Trader Rating: (4)
i'd drop a cobra engine.
im planning on doing the same in a lil' bit.
Old 09-13-2006, 12:50 PM   #3
you smell that?!
311-420's Avatar
cant go over 425 with your stock 2v. i'd go with a cobra/mach 1 4v swap. they both have high hp capabilities.
if 425 sounds like enough for you, i'd look into roush chargers. mine made 360rwhp with only exhaust and the stock 6psi.
04 Mach 1- K&N drop-in, Roy's 3/8 spacer, Steeda tri-ax, Pypes o/r X, Super 44s, 04 Cobra IRS, 4.10s
Old 09-13-2006, 01:51 PM   #4
well i'm planning on to everything i can i this GT that it could take...i just want to be able to keep up with the bigger boys...
Old 09-13-2006, 02:06 PM   #5
in a happy place
TrueBlueVenom's Avatar
if you don't do a cobra engine swap, ya gotta hit internals on the GT engine. small RPM ownz you. cobras redline at 6850; GTs at 5250
Old 09-13-2006, 02:22 PM   #6
Giving up
i'd say just pull a 03 cobra drivetrain from a wrecked cobra, but keep you solid axle unless you are gonna be auto-xing
Old 09-14-2006, 06:18 PM   #7
you will spend a easy 3000 to 3500 on labor doing the complete cobra swap for installing the motor the harnes cooler pumps etc everything else and doing it right.
then you still need to buy the cobra motor and you need to add the parts to make it fast ie blower etc if a na four valve or pulleys headers etc for a 03 cobra motor.
03 cobra motors are expensive also along the lines of a good 6 k for a motor and trany together.
or you could build a 2 valve with a good crank rods and pistons port the heads add cams and a super charger and you got 550 + at the wheels all day and never have to worry about the problems conversions can cause with wireing etc.
don;t forget about the 03 cobra motors 150 pounds of extra weight also so the car would be slower then a two valve making comparable power.
either way would probly be close money wise for a na 4 valve swap then adding a blower vs a built to the hilt two valve and blower the 03 cobra swap would cost more then either of those options
but with the built two valve you got a brand new engine not a unknown condition used motor and trany and on top of that you got a motor wich can take far more power then the stock cobra short block can handle unles you go 03 cobra motor
Old 09-14-2006, 08:06 PM   #8
i'm might go just build cuz i got an auto...and just do the internals...i'm trying to get to the 350 horsepower...
Old 09-16-2006, 04:33 AM   #9
I am my post count!
Last I checked new 03 Cobra motors are 14K.......kinda kills the buzz. I haven't seen used 03 Cobra engines floating around every day either.
350....supercharge it and call it a day.
Mestizo is offline   Reply With Quote
