turbo, supercharger, engine swap
so heres the deal, in about 10 months my car would be paid off.....so this means i'll have more money to put towards it...i always love the 03-04 cobras..and well i don't want to gain a another car payments so would it be best to swap out the enigne with a cobra with all all the works, or should i just drop in a supercharger or maybe a turbo or two...i do plan on getting a beater to let the stang rest....any info will work...thanks
you smell that?!
cant go over 425 with your stock 2v. i'd go with a cobra/mach 1 4v swap. they both have high hp capabilities.
if 425 sounds like enough for you, i'd look into roush chargers. mine made 360rwhp with only exhaust and the stock 6psi.
94 Steeda- sold- 355rwhp on a 75 ![]() 02 Roush 360R- sold- 400rwhp at 8psi ![]() 04 Mach 1- K&N drop-in, Roy's 3/8 spacer, Steeda tri-ax, Pypes o/r X, Super 44s, 04 Cobra IRS, 4.10s
well i'm planning on to everything i can i this GT that it could take...i just want to be able to keep up with the bigger boys...
you will spend a easy 3000 to 3500 on labor doing the complete cobra swap for installing the motor the harnes cooler pumps etc everything else and doing it right.
then you still need to buy the cobra motor and you need to add the parts to make it fast ie blower etc if a na four valve or pulleys headers etc for a 03 cobra motor. 03 cobra motors are expensive also along the lines of a good 6 k for a motor and trany together. or you could build a 2 valve with a good crank rods and pistons port the heads add cams and a super charger and you got 550 + at the wheels all day and never have to worry about the problems conversions can cause with wireing etc. don;t forget about the 03 cobra motors 150 pounds of extra weight also so the car would be slower then a two valve making comparable power. either way would probly be close money wise for a na 4 valve swap then adding a blower vs a built to the hilt two valve and blower the 03 cobra swap would cost more then either of those options but with the built two valve you got a brand new engine not a unknown condition used motor and trany and on top of that you got a motor wich can take far more power then the stock cobra short block can handle unles you go 03 cobra motor Last edited by psiperformance; 09-14-2006 at 06:22 PM. |
i'm might go just build cuz i got an auto...and just do the internals...i'm trying to get to the 350 horsepower...
