Old 05-05-2008, 04:48 PM   #1
if you ain't first your last!
turbo4point6's Avatar
UPR A-ARms which balljoints?
just wondering if it better to use the the x2 balljoints off my stock a-arms or use the ones the in the upr a-arm?
2004 Mustang GT
9:1 Forged shortblock .20over w/team breed valve covers, ported heads, turbo cams, stock intake, stock manifolds, cai w/kn filter, c&l plenum, prochamber pipe dumps, battery relocation, 3.90's, qa1 k-member, subframe connectors, upr a-arms/coilovers, bumpsteer kit, steeda X2 balljoints, tokico adjustable drag struts/shocks, upr cc plates, tubular upper and lower rear control arms, welded axle tubes, 18" DD Black Cobra R's wrapped in nittos
www.cardomain.com/id/66mustang04
T-70 Single Turbo build in progress...I cant wait!!!
turbo4point6 is offline   Reply With Quote
Old 05-05-2008, 08:14 PM   #2
thesource's Avatar
Trader Rating: (11)
I believe they use stock ball joints from a fox body or atleast thats what they told me .
Old 05-05-2008, 08:21 PM   #3
I eated it..
Trader Rating: (14)
If it is lowered more then 1 inch, I'd replace them with the Steeda ball joints designed for lowered cars. If not and the arms already have the ball joints installed, just use them. Better to be new then used.
Originally Posted by Ryan_65Stallion
lol. I love you to Jody
Old 05-09-2008, 02:47 PM   #4
well i called steeda and they dont have a part number for the boot that goes on the balljoint (which is torn) they said i need to buy all new balljoints wtf ??? steeda sucks
2004 Mustang GT
Old 05-10-2008, 01:16 PM   #5
I eated it..
Trader Rating: (14)
To my knowledge, you cannot buy those boots at all. If you really wanted to be sneaky, go buy a stock replacement from any parts store, snag the boot, then return it as missing parts. But to get that far down to the boot, it is just plain smart to replace the whole joint.
