UPR A-ARms which balljoints?
just wondering if it better to use the the x2 balljoints off my stock a-arms or use the ones the in the upr a-arm?
2004 Mustang Fobra www.cardomain.com/id/66mustang04 T-70 Single Turbo build in progress...I cant wait!!! |
I believe they use stock ball joints from a fox body or atleast thats what they told me .
![]() When the lights drop , the bullshit stops .Texas Motorsports Myspace Texas Motorsports Photobucket |
#3 | |
What's it gonna be?
If it is lowered more then 1 inch, I'd replace them with the Steeda ball joints designed for lowered cars. If not and the arms already have the ball joints installed, just use them. Better to be new then used.
well i called steeda and they dont have a part number for the boot that goes on the balljoint (which is torn) they said i need to buy all new balljoints wtf ??? steeda sucks
2004 Mustang Fobra www.cardomain.com/id/66mustang04 T-70 Single Turbo build in progress...I cant wait!!! Last edited by turbo4point6 : 05-09-2008 at 03:14 PM. |
#5 | |
What's it gonna be?
To my knowledge, you cannot buy those boots at all. If you really wanted to be sneaky, go buy a stock replacement from any parts store, snag the boot, then return it as missing parts. But to get that far down to the boot, it is just plain smart to replace the whole joint.
