Old 06-26-2008, 11:18 PM   #1
greenjams's Avatar
Vibration Problems
On my 94 GT resonantly its been vibrating really bad and i dont know if it is the motor mounts or the balancer is there any why to test the balancer.
greenjams is offline   Reply With Quote
Old 06-27-2008, 03:07 AM   #2
ANRmotorsports's Avatar
Trader Rating: (10)
Look to see if the rubber ring on the balancer is seperating, if so that would cause a imbalance which would cause a motor vibration.
ANRmotorsports
7190 E.1518 N.
Schertz, TX 78154
New and Used mustang parts.
ANRmotorsports is offline   Reply With Quote
Old 06-27-2008, 11:09 AM   #3
vibrating at idle?
you can see the balancer off balance. or with it off like stated above, feel the back for ruber being pushed out. They are easy to replace.
Old 06-28-2008, 12:59 AM   #4
greenjams's Avatar
the rubber is sticking out a little bit about 1/4 of the way around the balancer.
Old 06-29-2008, 11:42 PM   #5
BHAM's Avatar
time for a new balancer
BHAM is offline   Reply With Quote
Old 06-30-2008, 09:28 AM   #6
Closed for the season
REDHOT86's Avatar
get it fixed right away or you might mess up your crank... and that would be devastating. -JM
Mods: 3.73s, Shorties, MAC o/r H pipe, MAC catback, AOD w/shift kit, MAC cold-air, Underdrive Pullies, lowered 1.5" all the way around T5 CONVERSION COMING SOON!!!
Originally Posted by 04Roush2 View Post
All that money and will still sound like a weed whacker
REDHOT86 is offline   Reply With Quote
Old 06-30-2008, 01:12 PM   #7
most 5.0s that go, go because of this.
Old 07-01-2008, 09:17 AM   #8
REDHOT86's Avatar
Old 07-01-2008, 11:16 AM   #9
keg65's Avatar
You'll be able to compare the new one to the old one and see that the weight is in a different location from the keyway
Old 07-02-2008, 07:53 PM   #10
greenjams's Avatar
where is a good place to get one for cheap.
Old 07-02-2008, 08:19 PM   #11
I don't want a LARGE Farva...
FoxBodyNut's Avatar
key point no one else has mentioned: does it vibrate relative to rpm's and when in neutral, or does it vibrate only while you're driving. Among other things, drive shaft u-joints going out cause vibration in the driveline, but only when you're driving. Just thought i'd point out something that happened to me back in the day. i'd check for play in the driveshaft or rear end if you arent sure of the balancer
Old 07-02-2008, 11:38 PM   #12
thunderchicken's Avatar
But don't let it run for to long you could mess things up internally,or cause premature wear after repairs have been made.....
Old 07-03-2008, 09:15 AM   #13
REDHOT86's Avatar
Go get a new one from oreilly auto parts for $60 (house brand) and of course it will cost more for the other brands. They come with a 1-2 yr warranty as well. -JM
