Old 10-16-2007, 08:40 PM   #1
Fred
Weird Vibration
I have an 89 5.0 gt. I just recently had new motor mounts put on, and had my drivsaft re-worked and balanced. But im getting a weird vibration between 3000and3500. If you have any ideas please let me know....I think it might be the harmonic balancer so if you have had a problem like this then please let me know!
1989Gt 5.0;302bored .030 over, gt40 heads ported and polished, typhoon upper and lower intake, 70mm throttlebody, mac coldair intake,bbk underdrive pullys, smog pump delete, mac equal length headers, mac o/r x-pipe, mac highflow mufflers,borg warner 5speed tranny,kingcobra clutch,ford racing flywheel, 4:10 gears, steeda tri-ax shifter, and last but not least 17by9 chrome cobra r rims!
silverstang/306 is offline   Reply With Quote
Old 10-18-2007, 10:33 PM   #2
highspeed's Avatar
It's possible the vibration could be the balancer... But if it started after your driveshaft was balanced, my bets would be on that. One other possibility is one of the wheels could be slightly out of balance. But again, unlikely if the vibration began right after the driveshaft was balanced.
Something to try, rev the motor around the 3000-3500 RPM range while the car is sitting still and see if the vibration appears. If the vibration does appear, you just eliminated the driveshaft and wheels. That may help narrow things down... Good Luck!!!
Modz Update!!!
WTB: I need the following parts for my '94 Stang. PM me if you have any one of the listed components laying around or know someone that does.
  • MAF support brace - '94 GT
  • Maximum Motorsports Panhard Bar
  • Canton radiator overflow reservoir
  • Fidanza or Spec Billet Steel Flywheel - (50oz 302cid 10.5" 157 tooth)
  • T56 Tranny with 5.0L Bellhousing & support brace
  • Maximum Motorsports Tubular K Member
  • Maximum Motorsports Tubular A Arms (std offset)
  • Coil over struts
Old 10-19-2007, 05:08 PM   #3
Fred
ok cool ill give that a try. thanks!
Old 10-19-2007, 05:40 PM   #4
highspeed's Avatar
No Problem...
Modz Update!!!
  • Coil over struts
Old 10-22-2007, 12:35 PM   #5
Fred
ok so i tried that and it didnt vibrate so what else could it be? Oh and its not the wheels there all good.
Old 10-22-2007, 12:40 PM   #6
If you id as posted above and got no vibration Id say your D/S is not properly balanced.
You may try un bolting it at the rear end and turn it 1/4 turn and re attach it then drive it and see if it is better or worse you may have to move it a couple times. If it doesnt get better take it back and have um re balance it
Old 10-22-2007, 01:32 PM   #7
Fred
Ok ill give that a try. Ok im not a master mechanic but if it was the drive shaft wouldnt you get a vibration at any rpm? Just wondering.
Old 10-22-2007, 02:08 PM   #8
Not necessarily it may just have that spot that the harmonics are out of whack
Old 10-22-2007, 02:15 PM   #9
Fred
Ok cool thanks!
Old 10-23-2007, 12:44 PM   #10
UT Sucks
When you experience the vibration at speed push the clutch in. If the vibration goes away then it is most likely between the balancer on the engine and the clutch assembly. If the vibration persists it is from the input of the tranny to the wheels. If this is the case do this again only put the tranny in neutral. This will only engage the output shaft of the tranny and futher isolate the problem to the output shaft to the wheels.
My biggest concern is you are saying is occurs at a specific rpm range. Is this in all gears?
Darren
Old 10-23-2007, 07:19 PM   #11
Fred
Yes it occurs in first all the way through fifth. I will give that a try though.
Old 10-23-2007, 07:31 PM   #12
UT Sucks
If it is not a speed related thing and only based on RPM then is has to be something from the harmonic balancer to the output shaft of the transmission but not including the output shaft as it continues to increase in rpm as you change gears. Basically from the output shaft of the tranny to the wheels have now been eliminated.
Darren
Old 10-23-2007, 07:34 PM   #13
Fred
Ok cool thanks. So basically what your saying is that no matter what im going to be dropping some big bucks to get this fixed?
Old 10-23-2007, 07:49 PM   #14
UT Sucks
Not saying that at all. Could be as simple as a bad harmonic balancer. You need to start with some known good parts from friends like a balancer. All that costs to change out is your time and it eliminates once source. Another freebie is to take the serpentine belt off or get a shorter one that will allow you to eliminate the accessories like the alt, A/C comp, power steering pump, and water pump. If you know someone with a good tranny then you could change those out...
On another note what kind of motor mounts did you just install?
Darren
Old 10-24-2007, 09:08 AM   #15
You can try removing the belt and firing it up for a minute to see if it vibrates still if so it is the harmonic. However they usually will cause vibration as soon as you start it and at any rpm (usually increases as rpm's increase)
Id say that is probably were your problem is.
Old 10-24-2007, 12:33 PM   #16
Fred
Darren
I just installed poly mounts. And if i have to replace the balancer whats a good one to go with? Also i have a borg warner 5 speed tranny and its fairly new.
Old 10-24-2007, 04:30 PM   #17
UT Sucks
I would recommend a Romac balancer any day of the week.
Another question, when excactly did you notice the vibrations? After the DS install and motor mount install? If so then I would definitely suspect the poly mounts have simply amplified the vibration as they will translate all kinds of vibrations and harmonics unlike the FoMoCo engine mounts. Continue to try and isolate the problem but it may as simple as the motor in your car is not balanced to a tolerance that will not get you a vibration with the poly mounts.
Darren
Old 10-24-2007, 06:48 PM   #18
Fred
We started to notice the vibs about a week ago and we did the motor mounts and th ds about 2 months ago. Is there anything i can do to make it run smoother if it is just cause of the motor mounts?
Old 10-25-2007, 09:09 AM   #19
UT Sucks
All the poly motor mounts would do is amplify the problem not cause one. Being that you installed them 6 weeks prior to the problem occurring I would say they are not an issue at this point. You need to start diagnosing the problem like we have mentioned above. Start simple and cheap and work your way up. Keep asking questions as you go so you just don't throw money at it.
Darren
Old 10-26-2007, 02:06 PM   #20
Fred
Ok cool thanks. If you are going to the dyno day tomorrow then you can look at my car maybe or drive it to see if you can figure it out cause at this point im at a blank.
