Went to the shop but alignment still off.. help please *pics*
Went to the shop today to get my alignment done after the steeda spring install + tokicos shocks/struts install..
My c/c plate is still stock.. here are the result: ![]() ![]() ![]() Any help would be great... I'm not in a very good mood right now ![]() Will this be okay? It's not off that much.. I would probably get new c/c plate soon... but would like to see some input from you guys..
2003 GT Premium Exterior: Black Vert 5-Speed ![]() Pics/Dyno Graph/Other goodies Clicky Clicky Updated 07/03/04 |
I take it you have lowered it right?If so you will need the C/C plates.You can also purchase a shim kit through Ford which will be cheaper than the plates.The part # is F4ZZ-3B440-A. It is a smaller spindle to strut attaching bolt and a wedge to keep the spindle from shifting.They should be around 25-30 bucks each.You will need 2 of them.Looking at your camber it is way off and you will chew the inside edge up in no time.
