Results 1 to 7 of 7
Thread: What the difference between these Rods? Besides price?
    LoneStarStangs Addict Regular Member
    Jul 2008
    Ingleside,TX
    Dec 2007
    Marion
    Most likely they are the same quality as the Eagle rods, but I would not try them out in an engine that is making 800 hp. The Chinese are making a lot of the parts that are sold in the U.S today. Most all of the cranks and many of the aftermarket rods are made there.
    crazy racist right wing lunatic thesource's Avatar
    Nov 2004
    in a hole building transmissions
    The difference is the brand thus the difference in price. I'd bet they use different rod bolts as well which could be part of the price difference. I can tell you the Eagle H Beam rods are damn good for the price.
    Jul 2008
    Ingleside,TX
    Thanks
    Dec 2007
    Marion
    Quote Originally Posted by thesource View Post
    I thought they used cheaper rod bolts myself, but I read the whole add and found they seem to be using the same ARP rod bolts, they list the rod bolts as 7/16" 8740 bolts, the common ARP bolts used in most H beam rods are 7/16" 8740. They even say they have an option to upgrade to 2000 rod bolts, which I am gessing would be ARP 2000.n They do not say ARP anywhere in the add. I would suggest contacting them to find out what type of bolts they do use.
  6. #6
    Nov 2004
    Quote Originally Posted by Sonic Blue 85 View Post
    The devil is in the details. I'd bet they are not ARP.
  7. #7
    you smell that?! Regular Member 311-420's Avatar
    Sep 2004
    Big Tex
    be sure to use quality fasteners. thats one of the most common failures. id use arp 2000 if it was gonna be my engine.
    '04 Mach 1--5 spd, IUP, '04 IRS, Bolt-ons
