Still hiding from the LS1 guys. LOL
What does everybody think
What does everybody think of smoked tailights??? 2 wkends ago they had the mach1 vs bullitt shootout here and lufkin and saw many bullitts with them and they look awesome from far away. talked to a few of them and the replied that they had them painted. Im thinkin of doin it since my car is black. What do yall think? One other thin should i also get my rear side reflectors sprayed??
2002 Mustang GT-K&N FIPK, Accufab Plenum/ 75mm T-body, Diablosport Predator, 4.10s, Pro 5.0 shifter, Bassani O/r x-pipe, Magnaflow Magnapacks, Steeda pulleys, Mickey Thompson ET streets, Moser axles, Eibach Sportlines, Hotchkis U/Lca's, 180* t-stat_ best e.t 13.61@104 |
Hmmm... and i dont wanna go too dark to give the cops a chance to fuk with me.
You will never get this
Can paint and body shops do them?
Insert title here
I have mine done, I like them. No problems with the law yet..
http://www.lonestarstangs.com/forum/...l-hpim2974.jpg http://www.lonestarstangs.com/forum/...l-hpim2975.jpg http://www.lonestarstangs.com/forum/...l-hpim2976.jpg
#8 | |
Insert title here
I did mine with VHT Nite Shade, which I can't find anymore here locally in auto parts stores.
2 light coats of paint and 2 coats of clear with some prior sanding with 2000 grit sand paper and a light buffing.
Sup mando ima have to holler atcha. How many coats should i do?? Dont want em to dark...maybe as dark as davids civic. What do you think?
Stroked and Procharged
I like em
