Old 02-08-2007, 10:43 AM   #1
What gears should I go with?
I am debating on what gears to run in my 03gt I had 3.73s in my 98, but I keep hearing 4.10s for the newer cars. I need some help here im really confused!
myblack93gt is online now   Reply With Quote
Old 02-08-2007, 11:03 AM   #2
any all motor 4.6 or 5.0 will do better with 4.10s or higher if the RPM capabilities can support it.
Old 02-08-2007, 11:17 AM   #3
'98GT-4.10s-Flows
Ive been really happy since I got the 4.10s installed my '98.
Sven is offline   Reply With Quote
Old 02-08-2007, 07:50 PM   #4
you smell that?!
311-420's Avatar
which basically means if you wanna run 4.10s and get the most out of them, you probably wanna upgrade your valve springs(dont want valve float high in the rpms).
04 Mach 1- K&N drop-in, Roy's 3/8 spacer, Steeda tri-ax, Pypes o/r X, SLP catback w/Super 44s, 4.10s, 04 IRS
Old 02-12-2007, 11:39 PM   #5
the wheel goes round
CrewChiefLite's Avatar
How much do you drive the car? I went with 3.73's, and it is barely tolerable at 70 on long trips. Forget about cruising any faster than that.
Car
Car
Car
Truck
Old 02-12-2007, 11:50 PM   #6
I have a set of 3.73's i'll let go.
MIKE
'86 GT:high 12's
Sold
'01 GT:low 11's
for sale
Old 02-13-2007, 12:00 AM   #7
Giving up
410's or bust
Old 02-13-2007, 02:51 AM   #8
Wait...Auto or manual?
Car
Car
Car
Truck
Old 02-13-2007, 03:31 AM   #9
PHL 4 LIFE
YZF Voltage's Avatar
Send a message via ICQ to YZF Voltage Send a message via AIM to YZF Voltage Send a message via MSN to YZF Voltage Send a message via Yahoo to YZF Voltage
3.90's if you dont wanna go as high as 4.10
nickelback rocks.........almost as much as Lobra.
Originally Posted by BigJnSA View Post
*timpryor* HELL YEAH, I SUCK TOES! *timpryor*
YZF Voltage is offline   Reply With Quote
Old 02-14-2007, 01:33 AM   #10
tire's Avatar
y'all seem a little scared of some gear.
on my 2000 v6 5spd (which didn't rev very high) i had 4.10's and thought them perfect. i think 4.30's would have been too much.
i have only heard that the 4.6 can handle more gear than the 5.0s/3.8s. <--nothing credible, just the opinions of several people. this is making me lean towards 4.30's.
on my 2000 gt 5spd, i'm still undecided. it'll either be 4.10's or 4.30's though.
Old 02-14-2007, 10:18 AM   #11
Not hot..
Chili's Avatar
I went with 3.73's because I mistakenly thought I would someday have the cash to put a KB on the car.. 2 years later and no KB in sight, I wish I had gone with the 4.10's..
2004 Torch Red GT
Best 1/8 8.61 @ 81.59
Old 02-14-2007, 10:30 AM   #12
lazer96gt's Avatar
3.73s already make hard for me to get hooked and I'm running 275mm tires out back. Race it 4.10s, cruise it with pep 3.73.
96 SVT#6858 of 7496
http://videos.streetfire.net/video/9...bra_193899.htm
Old 02-14-2007, 10:30 AM   #13
Not hot..
Chili's Avatar
What size tires you running? With stock tires and 3.73's on your t45 in 5th you should be at 2,289, with 4.10's it would jump to 2519.
For this guy, in his 03 (3650) 3.73's at 70 would put him at 2,118, 4.10's would put him at 2,329. That's not bad at all.
2004 Torch Red GT
Old 02-14-2007, 11:27 AM   #14
'98GT-4.10s-Flows
I havent noticed that much of a difference in my gas mileage since switching from 3.73s to 4.10s...
In my opinion, any minor drop in gas mileage is outweighed by the "fun factor" the 4.10s provide.
Old 02-14-2007, 12:41 PM   #15
I don't want a LARGE Farva...
FoxBodyNut's Avatar
when i hear this question, i always say:
think of what your projected power will be and what speed you want to cross the finish line and at what RPM/gear, that'll be the deciding factor on gear ratio. there are several calculators online that'll help you determine the best ratio based off trap speed/hp.
EG: 350hp car trapping just over 100mph is fine with 4.10s in 4th gear, maybe even 4.30s since the mod motors can rev higher than pushrods...
500hp car trapping 120+mph, 4.10/4.30 could be too much gear for that mph in 4th's top end, unless you've got a .80 5th gear(like in a 6 speed)
of course, if you have 4.10/4.30 right now and arent making much power... it could be beneficial in the short run, then if you step up with a power adder, a way to effectively lengthen your gears without changing the ring & pinion is by throwing some 28" tires under it, if your suspension will allow that.
i got 3.90s in my fox. they're great NA, but on the spray.. its cutting it close. im thinking about dropping back to 3.55 again. its a trade off.
Old 02-15-2007, 06:08 PM   #16
Bulldoser89's Avatar
If you are DDing the car go with 3.73s
If its only going to the track and down the stripe, Go with 4.10s they are fun but you lose some on the highway.
I had 4.10s in my 89 Hatch and have 3.73 in my Vert, the vert is mostly for cruising.....
But since the Mod motors can handle more Rev, go with the 4.10s........
Bulldoser89 is offline   Reply With Quote
Old 02-16-2007, 04:56 PM   #17
one2nv's Avatar
Originally Posted by timpryor View Post
410's or bust
werd... i wouldn't trade my 410's for nuthin ... don't fear the gear
4.10 gears, dr. gas x-pipe, spintech mufflers, eibach sportlines, kyb shocks and struts, 17x9 & 17x10.5 fr500's w/ 275/40 & 285/40, diablosport predator, mach 1 chin spoiler... more coming soon
one2nv is offline   Reply With Quote
Old 02-20-2007, 09:32 PM   #18
Kiss my shiney butt
Poisoned Pony's Avatar
Send a message via AIM to Poisoned Pony Send a message via Yahoo to Poisoned Pony
I'm going with 3.73's on my DD GT, but then again, I'm also getting a Paxton for it
2000 GT
black, 5-speed, wingless coupe
mods: alittle bit of this, alittle bit of that
Poisoned Pony is offline   Reply With Quote
Old 03-01-2007, 05:35 PM   #19
Jeramey@StrictlyPro.com's Avatar
I want some 4.10s!!! Anybody have a set for a decent price?
Jeramey
Strictly Performance
713-910-0111
StrictlyPro.com
Daily Driver - 08 FJ Cruiser 4x4
Weekend Car - 92 S-Trim Fox
Jeramey@StrictlyPro.com is offline   Reply With Quote
Old 03-01-2007, 07:30 PM   #20
you smell that?!
311-420's Avatar
when do you plan to go turbo? just asking, because i'd look into getting highway gears if you want to get the most out of it.
