Old 05-21-2007, 08:29 PM   #1
CraZy6's Avatar
What size MAF sensor is this?
Okay I got the car started today with the chip, but the car starts running rough and black smoke starts coming out the exhaust. I think I have a bad MAF sensor.
I thought it was a 24lb MAF sensor, but I could be wrong. This is what is on the sensor.
F2VF-12B579-A1A
AFH7-04
3M23
CraZy6 is offline   Reply With Quote
Old 05-21-2007, 11:14 PM   #2
CraZy6's Avatar
I found out this is a 19lb Maf SENSOR and I thought I have been running a 24lb MAF sensor all this time.
Old 05-22-2007, 03:43 PM   #3
LOL @ your mom
Trader Rating: (21)
You can always get the PCM calibrated for the MAF versus buying a "rated" 24# MAF.
Old 05-22-2007, 09:00 PM   #4
CraZy6's Avatar
Thats alright! I bought the C&L from quickgt. I don't like to wait.
