What size MAF sensor is this?
Okay I got the car started today with the chip, but the car starts running rough and black smoke starts coming out the exhaust. I think I have a bad MAF sensor.
I thought it was a 24lb MAF sensor, but I could be wrong. This is what is on the sensor. F2VF-12B579-A1A AFH7-04 3M23__________________ |
LOL @ your mom
You can always get the PCM calibrated for the MAF versus buying a "rated" 24# MAF.
