Results 1 to 8 of 8
Thread: What thermostat does Ford Racing use in their 302 Boss crate engines?
    LSS Regular Regular Member marunos's Avatar
    May 2008
    Oman
    Hello,
    I installed crate engine M-6007-X302B(302 CID BOSS BLOCK with GT-40 HEADS AND B CAM from ford racing) on my 1990 Mustang. Does anyone know what Thermostat does this engine have? 180 ?
    I am asking this because I find my gauge (Autometer Gauge hooked into thermostat neck) is reading temperature at about 200-210 F. Also, my stock gauge would read at this range. The temperature where I live is about 42-45 C and the humidity is very high. So am I in the right range of the engine operating temperature? Note that I do not have any coolant leak.
    ________
    MAGIC FLIGHT
    Jun 2003
    Trashcanistan
    Factory thermostat was a 192.
    May 2008
    Oman
    Quote Originally Posted by 12second5.0 View Post
    I was just told that this engine does not come with thermo.. so I would check the one it has right now. Some people say 200-210 does not sound high. I was just wondering because my brother's stock 5.0 would read about 175-185 and he is living in a place where temp is about 35-38 C right now. So I am not really sure is it the place, engine or something is wrong with my cooling system!
    ________
    BMW TURBO HISTORY
    Dec 2003
    SanAntonio
    I have a 180 and a 100% new cooling sys (rad pump etc..) with elec fan set to come on at 200. Car runs 200-210 even in 100+ temps. The motor needs some heat to perform best 210-220 is not hot at all.
    85GT FACH1 FINISHED
    Dec 2007
    Marion
    I don't like running engines at anywhere over 190, GM likes to run their engine on the verge of be cooked, but not me. With the amount of timing Fords like, I would never run one hard, if the temps were any higher than 190. If the temps get any higher than 190, I would just baby it around until you can get it cooled off. I would stick with the 180 degree thermostat, that is probably the best choice for a Ford. Sounds like you may need more fan or radiator or both.
    Also since I don't have a thermomitter to look at right now, so I don't know what those air temps you are giving in celcius equate to in farenheight. So I have no clue how hot it is where you are, speak American.
  6. #6
    Dec 2003
    SanAntonio
    that is 98-100.4F
    Ron mine seems to do fine at 200-210.....Never gets any hotter than that even idleing in traffic. Usually it runs about 190-200 on the mech temp gauge.
    85GT FACH1 FINISHED
  7. #7
    May 2008
    Oman
    Quote Originally Posted by Sonic Blue 85 View Post
    You always can use online units converter
    Convert Temperature - Unit Converter
    42-45 C = 108-113 F
    35-38 C = 95-100 F
    You might be right, it is not recommended to run it at higher than 190. How about Power Stat 180 Hypertech thermostat? Any idea?
    ________
    Toyota U Engine
  8. #8
    May 2008
    Oman
    that is 98-100.4F
    It is the same with me, SOMETIMES it gets 210-215 in traffic, but it will run like 200 most of the time. My worries are that I am running my engine too hot, and this might have an impact on the engine's life.
    ________
    Extreme Q Vaporizer Review
