Old 08-26-2005, 06:49 PM   #1
you smell that?!
311-420's Avatar
What to go with
Ok, here's the deal...im rebuilding the steeders motor. i want suggestions on what pistons, rods, crank, gaskets etc. to go with. im having my heads reworked as well. I want to go with a 125 wet Edelbrock shot when done. What brands would YOU go with. thanks guys
04 Mach 1- K&N drop-in, Roy's 3/8 spacer, Steeda tri-ax, Pypes o/r X, SLP catback w/Super 44s, 4.10s, 04 IRS
Old 08-27-2005, 02:04 PM   #2
you smell that?!
311-420's Avatar
ok, i got a list together today from jegs.....tell me what ya think. PLEASE!
Pistons- SRP Flattop Forged-$450
Rods- Eagle I-Beam-$300
Rings- SpeedPro Plasma Moly-$100
Main Bearings- SpeedPro-$100
Rod Bearings- SpeedPro-$100
*Note* all of these prices have been rounded up.* Lemme know if anything sounds out of place or ridiculous. Thanks.
Old 08-27-2005, 02:42 PM   #3
i've heard its overkill to replace the rods in a stock 5.0 block because the block will go before the rods do. But I dont know how acurate that is.
My Garage
Old 08-27-2005, 05:45 PM   #4
In most cases that is true.
Old 08-27-2005, 06:12 PM   #5
you smell that?!
311-420's Avatar
hhhmmmm....i like the idea of saving 300 bones in rods
Old 08-29-2005, 04:08 PM   #6
you smell that?!
311-420's Avatar
:ttt:
Old 08-29-2005, 06:25 PM   #7
SALEENT76's Avatar
Cheaper is not always better!!!!
2002 Zinc Yellow Saleen #02-245
Hellion Power Systems T-76 Turbo
.20 VT Shortblock, Stock 2v Heads, MPH Turbo Cams
535rwhp, 506trq, 17lbs of Boost
Built and Tuned by MPH
"Power in the Hands of a Fool"
SALEENT76 is offline   Reply With Quote
Old 08-30-2005, 03:28 PM   #8
you smell that?!
311-420's Avatar
i wanna put about 425 to wheels with the spray and hit the elevens...does that sound too radical for stock rods?
Old 08-31-2005, 12:17 AM   #9
SALEENT76's Avatar
It sounds feasable, but then no engine is really fool proof built or stock!!!!
Old 08-31-2005, 12:22 AM   #10
sarcasm IS art
fastang7's Avatar
I'd look into a girdle while I had it apart
fastang7 is offline   Reply With Quote
Old 08-31-2005, 12:30 AM   #11
Nope! I have a stock short block and it put down 487 rwhp.Weakest point is the block.
Old 08-31-2005, 12:31 AM   #12
Waste of money.Spend it on ARP hardware instead.
Old 08-31-2005, 12:55 PM   #13
you smell that?!
311-420's Avatar
Now these are the kinds of responses I was hoping for! Thanks alot guys btw 12second5.0, what arp hardware should i look into. like i said, im doing a rebuild and porting my heads out more but am "somewhat" clueless as to the vital parts needed for my application. i am currently looking at a Ford Racing gasket kit, but dont I want to go with copper gaskets instead? im a little confused but want this project done right. i saved my money all summer and just want a sturdy motor that i dont have to worry about all the time. thanks again guys
Old 08-31-2005, 01:00 PM   #14
you smell that?!
311-420's Avatar
btw, that avatar is friggin' hilarious :rotf3:
Old 08-31-2005, 07:07 PM   #15
I am running the factory forged pistons,factory rods with ARP rod bolts,factory crank,block was torque plate honed.I machined the deck of the block with the pistons .018 above deck.I also had the machine shop hot tank the block and install the cam bearings and freeze plugs.I would suggest using ARP main studs,ARP head bolts,As far as porting stock heads,you can achieve some decent port numbers but for the time and work usually needed IMO you are better off with an aftermarket head such as AFR,Edelbrock,Canfield,etc.If you need more info just shoot me a pm.
