| General Mustang Tech General Mustang-related questions |
the wheel goes round
Wheel spacer question
If I were to run 15" Draglites on my car, what size spacer do I need for the fronts to clear the Cobra brakes?
Car Car Car Truck |
LOL @ your mom
I don't want to run something as permanent as that, since I'll only have the skinnies on a few hours every couple of weeks. The more I look into it, the more I doubt I'll even run them at all!
Car Car Car Truck |
LOL @ your mom
That is not permanent Kat, you take the original wheel off, put the new one on, the spacer goes first, then you just bolt it down...
I was told that you have to cut the stock studs to fit the wheel on...And how much is that gonna make the wheel stick out?
Car Car Car Truck |
LOL @ your mom
Good possibility on that spacer there, but if you had the 10 hole pattern, it may not be an issue,,,
but trimming the lug studs can be a slight dis-advantage when wanting ti return the stock wheels back on.
trojan man!
if that is seriously what you have to get, dont do it!
i bought those spacers a while back. I did have to cut my stock studs, and the spacer couldn't be torqued down for nothing. While driving, my damn wheel nearly fell off; they were on ebay that night.
![]() 2001 Kawasaki Ninja ZX6-R 2000 Mustang GT Bassani o/r x-pipe, flowmaster catback, 75mm tb & plenum, eibach sportlines, pro 5.0 shifter, k&n myspace |
speed-olic
I use the 1" hubcentric at the track with my centerline convo pros. I put them on at home and drive to the track and back with no problems. I actually drove with them for a week on the streets while I was being lazy and when I took them off they were still tight.
I had to grind the tips of the studs. Took about an hour for both front wheels and I still use my 18x9's up front with no problems after grinding. |
