Old 02-05-2007, 11:07 AM   #1
LoneStarStangs Addict
Allnuts's Avatar
Trader Rating: (-1)
Whine Noise thru speakers
I installed the an aftermarket radio on my 2000 Mustang GT, I eliminated the amp up front and splice into the factory according to the schematic for the 460 mach. I still retain the rear amps but I get this whining coming from the speakers. It's really getting on my nerves and changing the ground to a different place doesn't seem to help. Anybody have a solution?
Old 02-05-2007, 11:40 AM   #2
Its your alternator causing it you can get a filter from like radio shack (i forget what it is called) to eliminate the noise.
Old 02-05-2007, 01:43 PM   #3
Mr. Bobwehadababyitsaboy
VictoRR's Avatar
Send a message via AIM to VictoRR Send a message via MSN to VictoRR Send a message via Yahoo to VictoRR
Might wanna shield the power/ground from the speaker wires. It's common to have this kind of issue when you're routing RCA Jacks to a rear mounted amp along the power line also. When you separate the cables, the noise should go away.
Since you did just the radio, try shielding the power cable and see if that works.
2006 GT
www.centraltexasstangs.com
|Bassani X|Flowmaster AB|Demolet CAI|SCT-Bama Tune|CMCV Deletes|287rwhp/300rwtq (without CMCV's or Xpipe) Mustang Dyno
VictoRR is offline   Reply With Quote
Old 02-05-2007, 05:33 PM   #4
s197 here I come!
StAnGaLaNg's Avatar
samething happened to me and i went to radio shack and got that filter, it worked.
"There are three constants in life... change, choice and principles."
StAnGaLaNg is offline   Reply With Quote
Old 02-05-2007, 06:17 PM   #5
mustangluver98's Avatar
Send a message via AIM to mustangluver98
Same here! That is what we did to stop the whine when we installed my stereo!
Sig By: Me
My Rides:
2004 Ford Cobra SVT / MY TOY
1998 Ford Mustang V6 / Daily Driver
1965 Ford Mustang Coupe / Project Car
My Hubby's Toy
2001 T/A M6 WS6 RED (Twin Turbos are installed)
2003 Corvette Z06 (New Toy)
Lethal Performance (210) 656-5220
mustangluver98 is offline   Reply With Quote
Old 02-05-2007, 07:49 PM   #6
Allnuts's Avatar
Trader Rating: (-1)
Thanks ya ,will try that.
