Who Can Install Subframe Connectors Locally
I have my subframe connectors now and need to get them installed within the next month or so. I was wondering if there is anyone here in SA that can do it for a decent price? I can do it but would rather have someont that has done it before so i dont screw up anything. BTW, The Hot Rod Store quoted me $60 for installation. Thanks.
![]() 1988 Mustang LX |
Ooh-Rah Marine Corps
Murrillo Motorsports # is 946-1199. Give them a call.
Don't know how much, but mike will probably cut you a deal. BTW 60 is what I paid to get mine installed up in Ft. Worth
![]() 88 vert Be polite and professional, but have a plan to kill everyone you meet. |
Hey, smell my finger
Daniel, you can put them on. Those are so easy, Just put a good bead on the inside and out side of the frame rails when you weld. That has to be one of the easiest things to do. PM me if you have any questions.
I will give MMS a call and see what they say.
I want to do it and I know i can but I have no good flat surface to get the car squared to know that it is straight before I weld them on. I may do it myself if I can get some help and a good facility to insure a quality install, if not i will spend the money.
Problem
While I was installing my DS loop, I found where my floor cracked where the seat bolts down on the driver side causing the seat to lean out toward the door. I wonder if installing the SF connectors with the seat support will fix that or does anyone have another suggestion? I know they make the seat supports for the SSP cars that you can get from 5.0resto, and BTW this is a common problem for the FOX body cars.
SassyCassy's guy :P
I'm interested in getting SFC installed as well. What brand did you get? I was thinking about the full-length MMs. My 'vert is starting to creak a lot more, hopefully SFCs will stop it (or at least keep it from getting worse).
I ordered mine from D&D Motorsports. Good quality and they have the seat brace. I need to make some end brackets for them though just for the extra strength.
Check ya later!
I'm gonna get the Maximum Motorsports ones for mine.They are full length plus they have more bracing than the others.My buddy Mike can install them for you.PM me for details.:jeff:
#12 | |
#16 | |
#18 | |
#20 |
"The Hitman"
DAM ... sounds like we need a LSS SFC mod day..just need a shop and a/some welders....and beer of course....i need to do 2 stangs....
