Old 04-08-2008, 06:08 PM   #1
91mustang5.0j
91mustang5.0j's Avatar
Send a message via AIM to 91mustang5.0j
will a my t5 tranny work 351w ?
I just recently bought a 351w wit racing heads an cam from a friend so I'm takin my 302 out so I can upgrade most of the engine an know exactly wat my 302 will have in it ! so will this t5 bolt up to the 351w with out to much trouble I'm sure I'm gona have to change my bellhousings but wat else if any?
91mustang5.0j is offline   Reply With Quote
Old 04-08-2008, 08:07 PM   #2
Sonic Blue 85's Avatar
The trans will bolt up, the flywheel will be the problem. You will need a 157 tooth 28 oz. imballace flywheel. The 5.0 fly wheel is 157 tooth 50 oz. imballance. That is the first problem you will have, if the engine makes much power and the trans is not built properly it will not last long.
My car is an '85 sonic blue coupe with 302 bored and stroked to 364, Ported Twisted Wedge heads and a BXR intake, A9M ECM with a Tweecer, C4 with trans brake, 275/60/15 M/T drag radials, no power adders.
Old 04-08-2008, 11:45 PM   #3
Hi Yall
Boomer's Avatar
Here that about the flywheel problem with my 351W swap. I took my stock 302 flywheel to a local auto parts store to exchange as a core to get a new on, and took the new one to a machine shop to have it rebalanced to 28oz.
Don
1968 Ford F-250 Lunar Green
Old 04-09-2008, 11:14 AM   #4
UT Sucks
The T-5 will live as long as you don't hook up. Get it together and start looking for a Tremec to replace the T-5.
Darren
Old 04-09-2008, 02:17 PM   #5
thesource's Avatar
Trader Rating: (12)
As said above , you will need a 28OZ flywheel . Other than that the T5 will fit right in but probably will not last very long .
Old 04-09-2008, 06:50 PM   #6
RIP Cledus Snow
You need a 28 oz. 157 tooth flywheel. a 164 toooth WILL NOT work with a stock t-5 bellhousing.
Old 04-10-2008, 10:08 AM   #7
thesource's Avatar
Trader Rating: (12)
Ebay has them in billet steel for pretty cheap . 157 tooth , 28oz balance , 10.5 inch clutch disc .
