Results 1 to 7 of 7
Thread: window question, some one please help!
    Regular Regular Member ashleymarie's Avatar
    Jul 2010
    McKinney
    i am a new owner to a 05 GT. my question is can anyone tell me why my passenger side window will not go up automatticlly anymore. it was working fine but after i took it to get detailed it has stopped working. it still goes down automatically with just one push of the button but wont go up. im confused, is this a common problem or is there a way to switch this option on an off an the detail guys done it on acident. any info would be awesome.
    Thanks in advance.
    LSS SOTM Coordinator Weilding the ban-stick proudly Agent Jones's Avatar
    Mar 2006
    Texas
    Re: window question, some one please help!
    Just need to reset. Push the button all the way down and hold.then let all the way up and hold..then one touch should work
    Welcome
    Sent from my HTC Evo 4g using Tapatalk
    TUNED BY EAST COAST SUPERCHARGING
    AMERICAN RACING HEADERS - VARARAM INTAKE - BORLA EXHAUST - 3.42 GEARS
    Still a Spurs Fan What is SilverStar you ask?  Click here to find out! Dstang's Avatar
    Jan 2010
    San Antonio,TX
    This is a common issue that can be caused by low battery or anything else. It is nothing serious, I have an 06 and it happened twice in the past year. To reset the window turn on car and close doors. Pull up on window switch so that the window raises up and once the window has raised all the way up, keep holding the switch for 2 seconds. Then release and lower window. Window should now be reset and working. LMK if it worked.
    what the hell was i thinking Regular Member stang21034's Avatar
    Jun 2010
    san Antonio
    If it don't work mite need new regulator. It is a common thing with stang i have a 01 and ended up
    changing my internal parts in the door
    here it is
    Mar 2006
    Texas
    I will work if done right. It's a common thing on 05 +.
  6. #6
    Jan 2010
    San Antonio,TX
    Quote Originally Posted by Agent Jones View Post
    +1 happened to me twice in a year, and took two sec. to fix.
  7. #7
    Jul 2010
    McKinney
    IT WORKED!!!!
    It worked guys thanks a million!
