1. Welcome to LoneStarStangs, the #1 forum for Ford Mustang enthusiasts in Texas.
    If you haven't joined yet we invite you to sign up and join our community.
    Registration is free! Hope to see you on our forums!
Coolant disappearing but no visible leak
Discussion in '1996-2004 4.6 Mustang' started by Steve, Dec 18, 2010.
  1. Steve
    Steve Hi, I'm an Asshole.
    Dec 9, 2008
    6,975
    185
    Fucking your mother, trebek.
    I have coolant disappearing out of my reservoir tank thing, however there isn't any visible signs of a leak on any of the hoses or the ground.
    Car runs like a raped ape...doesnt get above the half point on the temp gauge or anything out of the ordinary.
    This means??????
  2. 2k4mk1
    2k4mk1 4 more years of this freaking IDIOT!!!! SilverStar Member
    Dec 2, 2003
    15,225
    297
    SanAntonio
    Run a pressure ck on it. U can get a loaner tool for it at the parts store
    If the pressure leaks down and you see no fluid it most likely means you popped a head gasket at the least.
    As you arent seeing any fluid it is most likely going out the tail pipes as vapor......
    Also do the pressure test with the car up to temp.
  3. Steve
    Dec 9, 2008
    6,975
    185
    copy that, gonna attack it tomorrow.
  4. KO pony
    KO pony Active Member
    Mar 6, 2007
    1,204
    1
    San Antonio
    the car would overheat if you popped a head gasket. and the oil would be milky.
  5. Steve
    Dec 9, 2008
    6,975
    185
    I've been reading different things, but I believe it may be the non OEM rad hose clamps...soo Im gonna run to ford tomorrow and try and get some.
  6. Steve
    Dec 9, 2008
    6,975
    185
    Broken non oem hose clamp under coolant reservoir...guess maybe I had overtightened it and stripped it, replaced it with the oem one I had just found, hopefully that was the issue.
    Tap uh talk app post...
  7. Mustang_68_Coup
    Mustang_68_Coup Libertatem! SilverStar Member
    Sep 6, 2005
    6,568
    11
    San Antonio, TX
    Also check, as I've been having mysteriously disappearing coolant, that your rad cap doesn't have a cracked gasket.... :facepalm: That evaporating vapor will make your level lower...
  8. Steve
    Dec 9, 2008
    6,975
    185
    i double checked that before taking her to work...might go for a spirited drive after work in the am to see if I fixed it by replacing that busted non oem clamp.
  9. thatdavidkid
    thatdavidkid just a little coupe
    Oct 3, 2006
    6,509
    14
    Denton
    not always... if the head gasket failure is between a cylinder and water jacket, it will burn coolant, causing the coolant level to go low which is the actual cause of the over heating. if he is keeping a close enough eye on it, it could just loose coolant and never get far enough for the over heating.
    as far as non oem clamp, if they're tightened propperly, they work just as well or better... but if it's a low quality one, they really are easy to strip out.. hopefully that's all your problem is.. the autozone pressure checker will likely not come with the propper fitting for the degas bottle.
  10. Steve
    Dec 9, 2008
    6,975
    185
    looks like it was stripped and wasn only tightened to be snug...so I replaced it. I hope that is what it is...kinda wanted to work on other things... like a blower or something fun.
  11. 2k4mk1
    Dec 2, 2003
    15,225
    297
    SanAntonio
    NOt always if the water is enter the combustion chamber it can go thru and out the tail pipe w/o overheating or milky oilll Of course left alone long enuf it will cause an overheat issue
  12. jstang6969
    jstang6969 "THINK WITH YOUR DIPSTICK JIMMY!"
    Sep 22, 2006
    4,305
    1
    Hamilton, Tx
    Does your car have an oil cooler? I have the same coolant disappearance issue your describing. I was told to check that. Just an idea if yours has it. Mine leaking is so far in between having to fill it up, I havent decided to mess with it.
Similar Threads: Coolant disappearing
Forum Title Date
1996-2004 4.6 Mustang coolant leak intake 04 gt= questions Oct 27, 2013
Classic Mustang Coolant on passenger side floor Apr 1, 2013
1979-1995 5.0 Mustang 5.0 Radiator/Coolant Hose Clamps Oct 24, 2012
1979-1995 5.0 Mustang Coolant in oil pan Jul 29, 2012
Parts FOR SALE/WANTED 96-04 coolant over flow tank Apr 10, 2012
Spread The Word
